Amtrol Quad Check
Tom M.
Member Posts: 237
Can anybody tell me how an Amtrol Quad Check operates? I was on a job where there were two of them which appeared to be manually open. I assumed that they operate in the same manner as a Taco Flowcheck but apparently they don't. After turning the knob down, there was no flow so I opened them back up and now the 2nd floor overheats.
Is there an operating range somewhere in the middle? Does the pointer on the knob have to point in a certain direction? There is no info on Amtrol's wesite, apparently no longer made.
Any help would be appreciated.
Tom M.
Tom M.
From fully closed......
turn the knob out 4 turns. That is the normal operating position. All the way down locks the wight down. Nice design, but I have had more than a couple leak through over the years.
hb
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Thank You
Thanks for the help and have a good weekend.
Tom M.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
