Expansion Tank Question
Rob T
Member Posts: 64
I asked this question once before and was told it wasn't a good idea to have two expansion tanks on a system due to the point of no pressure change.
At the time I could see why this would be a problem ( I still do actually) but was wondering if the setup shown in the drawing would work? Wouldn't the system see it as a single PNPC?
Just wondering as I want to keep my existing Fil-Trol setup but I think it is slightly undersized for my system. Fully heated pressure never exceeds 22# or so but I'd like to reduce that a little if I can. (Kinda a Tim the Toolman thing, got to tweak it...)
If it won't work, fine, I'll just get a bigger Fil-Trol in the spring..
Thanks
Rob
PS I always have the fill valve off if that makes a difference.
Thanks
Rob
no problem
That's OK.
Noel0 -
Multiple exp. tanks
Multiple expansion tanks aren't a problem. The drawing looks just fine. You may want to make sure the precharge pressures are the same on both units, so one is not moving more than the other, it's a very small point, but may make increase the life of your tanks.0 -
Thanks for the
info, I added a little more detailed drawing.
That's what I was hoping as I can get an Extrol Tank for next to nothing. I'll make sure that they are both set at 12# pre-charge.
Rob0
