3 Unit Brick, Chicago, No heat in raditor in 3 Floor Unit
G.E. Holston
Member Posts: 4
I have a 3 unit brick in Chicago. There is no heat coming from the 3rd floor unit in the living room only. The radiator and the supply to the radiator is cold. The 1st and 2nd floor unit raditors are all warm/hot. Someone says it may be a bleeding problem. Can you guys advise?
Can you provide more specifics0 -
Specifics
1. 3 units
2. Radiators in all units (6)
3. Gas fired furnace
4. Thermostat says 74 degrees actual, although dial says 70 degrees
5. the 3rd floor unit does not get as warm as the 1st and 2nd floor units
6. The living room radiator is totally cold. The supply line and valve is even cold.
7. I know it is something minor
8. HELP!!0 -
heat
> 1. 3 units 2. Radiators in all units (6) 3.
> Gas fired furnace 4. Thermostat says 74 degrees
> actual, although dial says 70 degrees 5. the
> and 2nd floor units 6. The living room radiator
> even cold. 7. I know it is something minor 8.
> HELP!!
heat
Is this gravity hot water with cast iron radiators? Is this steam? Is the backing plate on the thermostat level. Is there a pump on the system? Please give more detailed information so we can help you more easily. Give us a good visual.0 -
More specifics
Thanks Travis,
Steam heat, no pump, cast iron radiators in all units.0 -
If that radiator has only one pipe connected to it
it probably has a bad air vent. Remove it and see if air comes out the hole in the radiator- if so, put in a new vent and it should work.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
