Tarm woodfired boilers
Newt Loken
Member Posts: 12
Tarm USA recommends using a Termovar thermostatic valve to keep boiler return temperatures high (above 160 F I believe). For low temperature application radiant floor (mixed down slab)with a Solo plus & a large (500gal.) storage tank, can a lower temperature valve be used without risking condensation or effecting the gasification performance of the Tarm that make it such a high efficiency unit in the wood-fired realm.
Also, has anyone out there installed a Tarm in an open loop configuration, with boiler, tank and floor loops all the same water, taking the proper precautions with corrosion inhibitor and regular monitoring. Not recommended by Tarm for good reason due to potential for corrosion and premature failure and a bad product story that gets told. But for certain savy customers... open loop could be cost effective and there's a "no heat exchanger" performance boost. Any savy, but safe options out there?
Newt
Newt
Some like it hot
The Tarm is one of them. Keep it hot and keep it clean and you'll get some gassification. Follow the Manufacturer's requirements on this one. Enjoy.....Dan
Why?
would you want to run it open? Certainly for the cost of that nice unit you have the cash to use a HX and do it right
I'd stick with the manufactures instruction on this call.
hot rod
