When refilling boiler do you add any thing to the new water?
Joe.G
Member Posts: 213
I have hot water heat and I was wondering if you would adding anything to the new water that you put into the heating system when refilling the boiler. Thanks
need more details about your boiler
Need to know what kind of boiler ie steam or hot water
How many gallons and commercial or residential.
We specialize in water treatment of all types of systems, from boilers to hydronic systems.
Be happy to make recommendations if you would reply with details.
george0 -
I have a 1947 york hot water bolier ( ithink it could be used for stream to but I use it at as a hot water boiler)This is for my personel house, and I am not sure how many gallons the system is, I have a basement 1st floor and 2nd floor with old cast iron raditaors. Ihave a total of 8 or 9 of them. thanks
P.S the wtaer I use is well water, if My well ever stopped I do have a back up of spring water.0 -
Our web site has your answers
Joe
Go to our web site for the answers to your questions. It is
www.rhomarwater.com... we specialize in all types of system
water treatments. If you have further questions, you can then give me a call or an e-mail. Water treatment will certainly help your systems efficiency and extend its life with fewer problems.
George0
- 167 Indoor-Air Quality
