Tekmar indoor sensor
the new instructions...they look great! thank you ever so much for your help. I will get to work asap on it and let you know how it turns out! kpc
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    Tekmar sensor
    Can you substitute a tekmar rtu(057) for a indoor sensor unit on a Tekmar 260? tring to get my heat going today! kpc
  • hydronicsmike
    hydronicsmike Member Posts: 855
    057?
    057 is not a number I recognize. Do you mean an 054? Anyways, the answer is no. You can not use an RTU in place of an Indoor Sensor on the 260.
    Hope this helps.
    Mike
  • kevin coppinger_4
    your right....Mike
    it is a 054. I have not used a Tekmar, let alone a 260 control before. I am having a real problem wiring it. So far two blown fuses in the sr502 relay... I am going to need some help from someone @ FIA in Woburn,MA. kpc
  • hydronicsmike
    If you want...
    ...drop me an email with your number and I'll call you tomorrow.
    Mike
  • kevin coppinger_4
    Mike I tried....
    to e-mail you but the address listed bounced back to me...kpc
  • hydronicsmike
    Really?
    That is disturbing. I receive emails there all the time. Would you mind trying again?
    hydronicsmike@canada.com
    Looking forward to hearing from you.
    Mike
  • hydronicsmike
    Sounds great Kevin...
    ...I am glad I could help.
    Mike
