Tekmar indoor sensor
kevin coppinger_4
Member Posts: 2,124
the new instructions...they look great! thank you ever so much for your help. I will get to work asap on it and let you know how it turns out! kpc
Tekmar sensor
Can you substitute a tekmar rtu(057) for a indoor sensor unit on a Tekmar 260? tring to get my heat going today! kpc0 -
057?
057 is not a number I recognize. Do you mean an 054? Anyways, the answer is no. You can not use an RTU in place of an Indoor Sensor on the 260.
Hope this helps.
Mike0 -
your right....Mike
it is a 054. I have not used a Tekmar, let alone a 260 control before. I am having a real problem wiring it. So far two blown fuses in the sr502 relay... I am going to need some help from someone @ FIA in Woburn,MA. kpc0 -
If you want...
...drop me an email with your number and I'll call you tomorrow.
Mike0 -
Mike I tried....
to e-mail you but the address listed bounced back to me...kpc0 -
Really?
That is disturbing. I receive emails there all the time. Would you mind trying again?
hydronicsmike@canada.com
Looking forward to hearing from you.
Mike0 -
Sounds great Kevin...
...I am glad I could help.
Mike0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
