Blockage in closed loop system?
Steamhead
Steamhead Member Posts: 18,218
or it could be something else- like lots of dust or somehting else blocking air flow thru the baseboards.
Try the Find a Contractor page of this site to locate smeone near you who can straighten this out.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
  • ddormody
    ddormody Member Posts: 1
    blockage in closed loop system
    I have a closed loop hot water boiler system (about 30 years old) with three zones - one for each floor of the house. The main floor developed a problem last winter...the baseboard heaters in two of the rooms stopped working. All other rooms in the zone work fine. Do I need to get a plumber in to bleed the water out of the system? What could have caused a blockage?
    Thanks...
