Vitodens Redux- Fini-PGP
Michael B
Member Posts: 179
inspiration!! Thanks for the pics! What temp gauges do you use?
Michael Bleier
Able Distributors
www.abledistributors.com
"The Supplier That Works With You"
Michael Bleier
Able Distributors
Vito Done
We finished the replacement of a system that was connected to PB piping without a heat exchanger. The amount of sludge and iron in the system uafter 7 years was unbelievable. It took 3 chemical treatments to remove the particulates. The new setup uses a Vitodens 11-44, a 92g VitoCell 300 tank, a separate mixing valve for each zone temperature (concrete and gypsum) and the HK-1 for Mix temp #2. There's also a pump for the HW coil in the air handler. All pumps are stainless, and there are no ferrous components. (and no HX) We replaced all of the radiant manifolds with Wirsbo flo-port manifolds. We'll finish balancing when it gets colder. I've also included our method of installing a LW cutoff on the safety header, rather than build a trombone. On the air side, we added (2) Lifebreath TFP 3000 particulate filters to each air handler.
My only question in the system design is why the Vitodens requires a separate HK-1 for the 2nd mix temperature... why not integrate the Vitotronic 300 rather than the Comfortrol?
An amazing job
What is the Life breath air filter? Is it a Pleated HEPA filter or what? How many days and men were spent on a project of this size and complexity? WW
Beautiful, beautiful, beautiful,
And you even left room for the plumber to get a snake near the cleanout, beautiful job.......
Cosmo Valavanis
Dependable P.H.C. Inc.
Plumbing Heating Cooling0 -
HK1?
the comfortrol should be able to handle 2 zones plus the dhw by adding the second interface to the power supply for the mix valve. Assuming you are using all viessmann products - can you eloborate on the additional HK??0 -
TFP
The TFP 3000 uses a special HEPA filter. The project took 3 men 12 days.
Zoning with the vitodens
The Vitodens will do 1 mix valve and 1 high temp pump. To add the 2nd mix valve, the HK-1 is required. It's an independent outdoor reset module. Detailed info on Viessmann's website.
The walls
were also replaced with 5/8" white melamine boards over the SR. It's alot easier than waiting for the paint to dry and easier to set the hangers on.
The thermometers
Thanks!! The thermometers are by Letro. Sometimes we use the Weiss digital solar thermometers, but the Letro's are competitively priced.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
