A chimney size
Hi,
Just to let you know that I plan to replace from the old masonry block 16"x16", 6 1/2" square liner and its 32 feet high plus 2 feet over the roof. I use a boiler heater of the wood/hard coal.It's the Harmanstove SF-260. The woods is working wonderful, but not wonderful with fresh hard coal when an ash door open a full about 2 hours, then died. A boiler heater's flue size is 7 inch dia.
How can I figure what chimney size with 34 feet height ? or Can someone suggest me what best for my size and high height ?
The masonry store have 8"x 8", 8"x 12" and 12"x12" square liners.
Hope to help me,
Thanks, David Lee
  • Alan R. Mercurio
    Alan R. Mercurio Member Posts: 588
    Hi David, The following link will take you to a pdf file once the file opens you'll want to go to page 5.
    http://www.protechinfo.com/pdf/1153.pdf
    This shows a pretty good sizing chart.
    Your friend in the industry,
    Alan R. Mercurio
    Oil Tech Talk
    hot_rod Member Posts: 26,597
    Make sure
    you have adequate combustion air to that beast! You might have an HVAC pro take a look for healths sake :)
    Most of the flue pipe manufactures will help you size the chimney properly. Special pipe is required for solid fuel applications. Try Metalbestos at 1-800-992 vent.
    hot rod
