A chimney size
David L. Lee
Member Posts: 1
Hi,
Just to let you know that I plan to replace from the old masonry block 16"x16", 6 1/2" square liner and its 32 feet high plus 2 feet over the roof. I use a boiler heater of the wood/hard coal.It's the Harmanstove SF-260. The woods is working wonderful, but not wonderful with fresh hard coal when an ash door open a full about 2 hours, then died. A boiler heater's flue size is 7 inch dia.
How can I figure what chimney size with 34 feet height ? or Can someone suggest me what best for my size and high height ?
The masonry store have 8"x 8", 8"x 12" and 12"x12" square liners.
Hope to help me,
Thanks, David Lee
Hope to help me,
Thanks, David Lee
Hi David, The following link will take you to a pdf file once the file opens you'll want to go to page 5.
http://www.protechinfo.com/pdf/1153.pdf
This shows a pretty good sizing chart.
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
Make sure
you have adequate combustion air to that beast! You might have an HVAC pro take a look for healths sake
Most of the flue pipe manufactures will help you size the chimney properly. Special pipe is required for solid fuel applications. Try Metalbestos at 1-800-992 vent.
hot rod
Living the hydronic dream0
