GSHP question
[Deleted User]
What is the largest ground source water to water heat pump available in single phase power, and who makes it?
Thanks!
ME
Thanks!
ME
ck out
Waterfurnace & Climate Master. I've been looking at both in my "spare time".0 -
I just
Priced out a 6 ton, 2 stage from Carrier, made by climate master.0 -
8-ton
made by ECONAR, Appelton, MN. I have installed a couple water-to-air. Very good start-up and pretty fair tech support. I believe www.econar.com would get you to a website.0 -
Try Hydro-Temp
in Pocahontas, Arkansas. Sounds like they will build whatever you need.
See the cover story in the Aug. 18 issue of the ACHR NEWS
www.achrnews.com
hot rodBob "hot rod" Rohr
aeretech.com
seems to supply or build some large single-phase units
Hot Rod...looks like you checked out the company that says it's the "original."
REALLY wish I would have had my camera when I saw the prototype in a house. Three private electric meters to get accurate measurements; the longest mercury thermometer I've ever seen measuring the temp of incoming water (10ths of a degree were about 1/4" apart as I recall); EXCEPTIONALLY detailed records.
Owner collaborated with the builder for the prototype.
His spring feeds a man-made cypress swamp in the back yard, a stream with river otters (seriously), multiple catfish ponds and provides his domestic water via a gravity pump.
If you're ever heading that way (Pocahontas, AR) let me know and I'll arrange a visit. I don't know them too well, but they're old and close friends of my dad and his family.
Econar 120
The Econar 120 is a 10 ton, 2 stage unit available in single phase. We have specified them on a few projects, and have had good results.
August0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
