GSHP question
What is the largest ground source water to water heat pump available in single phase power, and who makes it?
Thanks!
ME
  • Tony_8
    Tony_8 Member Posts: 608
    ck out
    Waterfurnace & Climate Master. I've been looking at both in my "spare time".
  • Steve Ebels
    Steve Ebels Member Posts: 904
    I just
    Priced out a 6 ton, 2 stage from Carrier, made by climate master.
  • Bryan_16
    Bryan_16 Member Posts: 262
    8-ton
    made by ECONAR, Appelton, MN. I have installed a couple water-to-air. Very good start-up and pretty fair tech support. I believe www.econar.com would get you to a website.
    hot_rod Member Posts: 27,945
    Try Hydro-Temp
    in Pocahontas, Arkansas. Sounds like they will build whatever you need.
    See the cover story in the Aug. 18 issue of the ACHR NEWS
    www.achrnews.com
    hot rod
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    aeretech.com
    seems to supply or build some large single-phase units
    Hot Rod...looks like you checked out the company that says it's the "original."
    REALLY wish I would have had my camera when I saw the prototype in a house. Three private electric meters to get accurate measurements; the longest mercury thermometer I've ever seen measuring the temp of incoming water (10ths of a degree were about 1/4" apart as I recall); EXCEPTIONALLY detailed records.
    Owner collaborated with the builder for the prototype.
    His spring feeds a man-made cypress swamp in the back yard, a stream with river otters (seriously), multiple catfish ponds and provides his domestic water via a gravity pump.
    If you're ever heading that way (Pocahontas, AR) let me know and I'll arrange a visit. I don't know them too well, but they're old and close friends of my dad and his family.
  • Econar 120
    The Econar 120 is a 10 ton, 2 stage unit available in single phase. We have specified them on a few projects, and have had good results.
    August
