Pex choices
todd s
Member Posts: 212
For hooking up castiron radiators? These were for a two pipe system that we are converting to hot water. Each radiator is going to be a home run back to the boiler room. I didn't know if I should go with straight hepex or use a blend, we want to be able to run high temp if needed. Also, these don't have steam traps on them so does that mean there are orifices in the radiator valves?
I'm waving the
PAP banner a lot these days. I feel it is the best match for this application. I have used Weil, Wirsbo, Kitec, and recently some Vanguard. Give it a try.
hot rodBob "hot rod" Rohr
Living the hydronic dream0
