Pex choices
todd s
todd s Member Posts: 212
For hooking up castiron radiators? These were for a two pipe system that we are converting to hot water. Each radiator is going to be a home run back to the boiler room. I didn't know if I should go with straight hepex or use a blend, we want to be able to run high temp if needed. Also, these don't have steam traps on them so does that mean there are orifices in the radiator valves?
    hot_rod Member Posts: 26,594
    I'm waving the
    PAP banner a lot these days. I feel it is the best match for this application. I have used Weil, Wirsbo, Kitec, and recently some Vanguard. Give it a try.
    hot rod
