Forced Hot Air v. Forced Hot Water
ED_8
ED_8 Member Posts: 1
I am looking to switch over from forced hot air to forced hot water. Need to find some good contractors in Northern NJ. The plumbers I have talked to think it is not worth the hassle of installing the 3/4" piping throughout the entire house. The forced air system is bad for my allergies. I would tie in the existing supply ducts to an air handler for central a.c. for the summer. Any suggestions would be appreciated.
  • ScottMP
    ScottMP Member Posts: 5,882
    My suggestion
    Would be to keep looking untill you find a plumber or heating contractor who wants to work on your home. Its your home to do what you wish.
    Have you tried the Find A Contractor feature on this website ? Scroll to the top left of this page and clic on Find A Contractor and then use your zip code to find who's close by. Your on the right track to a comfortable home.
    Try Comfortable Home Technologies, Mark Hunt. He would be a great contractor for you if your in his area.
    Don't Dispare, your at the right site :).
    Scott
  • Joe_13
    Joe_13 Member Posts: 201
    Maybe hydro-air?
    While it's not the best, using a hot water coil for heat usually does not dry the air as much as a furnace. A good humidifier (if you need one) and a high end air filter system might be a beter investment.
  • Bill NTSG
    Bill NTSG Member Posts: 321
    Look For
    Palmer Heating, Ken Secor is a good heating man and really knows his stuff.
  • i would
    put basebord on the 2nd floor, and radiant on the 1st floor, you will be happy you did when you start ripping out the old ducts. bob
