5/8\" Crimp fittings, tool, and rings
hot_rod
hot_rod Member Posts: 26,486
available from Watts Radiant. A long in demand, fitting! Be nice for baseboard and large long loop radiant applications.
The tool will get a few mods, in my shop :)
hot rod
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    whose tubing...
    do you use that on? Watts? I didn't relize they made it in 5/8" I use the Wirsbo 5/8 a lot for baseboard a tid bit tricky in some spaces. Are they standard "vangaurd" style fittings? What modifications are you alluding to?... kpc
  • Bill NTSG
    Bill NTSG Member Posts: 321
    Is that............?
    a "go,no go" gauge in the upper left? and can you change heads to do other sizes? Looks kinda' like the old quest like tool we used to fix mobil home stuff
    Yes
    Watts Radiant offers 5/8 heating pex. I think most manufactures do. I need to modify the handles so the tool fits up into joist bays. I will make one removable.
    Yep on the go, no go gauges. Im think you are right about this tool looking vaguely familar :) The jaws are changeable with two allen bolts.
    hot rod
