just finished
Dave Palmer_3
Member Posts: 388
this today, 4 zones with hot water maker.Had to swap where boiler and water maker was because burner was only 3 feet from oil tank. Real pain to repipe but all worked out well. Dave
Very nice improvement Dave
I see you got some room to work on this one . Ahh the luxury . The pic is a little dark . I get that problem too when the batteries run low on the camera . I switched to rechargable Nickel Metalhydride AAs and they last a few weeks on a charge . Good job Dave and the shadowy figure in the background .0 -
thanks Ron
I think the problem might have been one light bulb in the corner. We just turned out the halogens.This is the house where the lady fed us.Breakfast(bacon,french toast-midmorning snacks and coffee, lunch and dessert,afternoon snacks)We were slow going but happy. Dave0 -
the
shadow is my guy Joe. he works all day THEN goes to his uncles diary farm to load hay bales!!!!!!!0 -
I noticed....
that you did not use a Honeywell 8148....Is that a 4080B? How is that wired and why did you go that route? I have had and continue to have problems with the accuracy of 8124 & 8148 aquastats....I am wondering if there was a better way to go....kpc0 -
with no tankless and 4 existing zone valves plus the hot water maker I just needed high limit. The switching relays have dry contacts to pull in the burner. We've had lots of over riding aquastats 10-20 degrees too,Dave0 -
is that the ...
way the boiler came packaged? kpc0 -
no
I swapped out the control. Dave0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
