Looking for adapters
John Smith
John Smith Member Posts: 5
I am looking for a reducing adaptor. Copper sweat connection on both ends. 1" female on one side and 3/4" male on the other. Thanks for any help
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    You should be able to find them at a good plumbing house. I have a number of ¾ x ½ in that configuration and am quite certain I've used 1 x ¾ as well.
    I call them 1" bushing x ¾" coupling and counter men know what I'm asking for...
  • Andy Morgan_2
    Andy Morgan_2 Member Posts: 147
    Another name
    > help
    Is a fitting reducer.
    Andy Morgan
    R. Morgan Mechanical, LLC
  • Andy Morgan_2
    Another name
    is a fitting reducer.
    Andy Morgan
    R Morgan Mech. LLC
    Sounds like the RIGHT name
    nm
    hot_rod Member Posts: 26,575
    If I'm reading you right
    You would need a 1' X 3/4" copper reducing coupling (also called a bell reducer) and a short nipple on the 3/4" end to give you a male sweat connection? Never seen such a fitting, but I'll bet they could be made.
    If you mean 1" copper X 3/4 MIP, those are common stock.
    hot rod
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    fitting reducers
    I think he wants to go the other way. The fitting reducers in my catalogs are all "large-ftg x small-C" and I think he wants "large-C x small-ftg".
    The only solution I see is 1"x3/4" reducer coupling and a "close nipple" of 3/4 tubing.
    Mark
