Radiant Steam
Ken_8
Ken_8 Member Posts: 1,640
We would like your opinion on the following situation....
A very substantial 100-year old house has a one-pipe steam system. To accomodate the all new "ultra" kitchen layout, the contractor ripped out the existing rad(s) in this large area and all that's left is a 3'X 8' horizontally hung rad under the kitchen floor - actually hanging from the basement ceiling directly under the center of the kitchen floor.
The kitchen floor is 8" thick concrete with an inch or so of mud on top - with embedded tight-weaved brick/tile surface. Quarter-sawn oak cabinetry and ultra-primo top-of-the-line showcase appliances.
The kitchen is cold. The 3 X 8 foot horizontal basement ceiling hung rad has a potential output of somtheing like 84 S.F. EDR.
The rad is turned off. We know by turning it on, we will get both radiant and convected heat into the 9-inch thick floor slab directly overhead.
You guessed it. We will turn on the rad, see what happens after a few days - and measure the upper surface temp to see what we can get woithout anything else than simply turning he rad back on. We suspect the slab will get a few degrees warmer - given enough time.
However, we suspect we could substantially enhance the underfloor rad's perfomance in heating the slab by eliminating the insulating nature of the 2-3" void between the rad's top face and the underfloor/slab.
Our thoughts were to place some wire mesh on the top of the already horizontal rad, pack the 2-3" void with cementatious material (concrete, mortar, etc.) and thereby induce conducted and radiant heating into the slab underfloor.
Any other ideas out there?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Ken_8
    Radiant Steam
    A very substantial 100-year old house has a one-pipe steam system. To accomodate the all new "ultra" kitchen layout, the contractor ripped out the existing rad(s) in this large area and all that's left is a 3'X 8' horizontally hung rad under the kitchen floor - actually hanging from the basement ceiling - directly under the center of the kitchen floor.
    The kitchen floor is 8" thick concrete with an inch or so of mud on top - with embedded tight-weaved brick/tile surface. Quarter-sawn oak cabinetry and ultra-primo top-of-the-line showcase appliances abound.
    You guessed it. We will turn on the rad, see what happens after a few days - and measure the upper surface temp to see what we can get without anything else than simply turning he rad back on. We suspect the slab will get a few degrees warmer - given enough time.
    Whaddaya think?
  • I like that.
    > situation.... A very substantial 100-year old
    > floor.
    > The kitchen is
    > 84 S.F. EDR.
    > directly overhead.
    > time.
    > Our
    > Whaddaya
    > think?
    > _A
    > 68&Step=30"_To Learn More About This Contractor,
    > Contractor"_/A_
  • I like that.
    > floor.
    > The kitchen is
    > 84 S.F. EDR.
    > directly overhead.
    > time.
    > Our
    > Whaddaya
    > think?
    > _A
    > Contractor"_/A_
  • I like that.
    What's the plan if it works too well?
    Maybe a remote bulb TRV on the vent line?
    I think it's going to condense a lot more than it used to, the supply might get overwhelmed with return water.
    I think it's a great idea, in view of the options. I know where two of these are in a basement, heating an outside patio above, as snowmelt. It works well, from what I saw.
    Noel
    P.S. Aren't we due for another trip out to Kennybobscottport, soon?
    Steamhead Member Posts: 18,444
    That might work
    but if it doesn't, some of those ultra-modern steam radiators might be the answer.
    Consulting
