Munchkin Problem??
Dave_13
Member Posts: 110
I have a friend who has a Munchkin 80M installed in his 2 year old home. Lately he has had problems with his "air proving switch" I would call it. It is locking out on this fault. It has been windy, so he tried to built a guard and shield it from the wind, but this hasn't seemed to help. Is this just a pressure switch that indicates that his combustion blower is running? Any ideas? Thanks
Hmmmm.
I thought someone would be on this quick!!!!
Pressure switch
Quite a few of the Munchkins had pressure switches that were installed to the component board with screws that were too long; the screw pierced the housing and prevented proper operation. I had 4 of them.
Check with your supplier or the factory to find out if yours could be one of them. Have the purchase date and serial number handy.
1 out of 6 are failing!!!!
I have had wholesalers tell me this. I talked to a contractor that has put in 40 of them and is having to many problems so he stop putting them in.
Ted0 -
Is it just the switch that has been the problem?? This one has a connector on the circuit board- there is no terminal strip that I see......0 -
The blower motor
goes out and switch and gas valve are the most common.
Ted0 -
shades of Voyager!!
Obviously the result of installer error!! Fool me once, shame on you; fool me twice, shame on me.
Bill0
