Differential Pressure Bypass valve
Kal Row
Member Posts: 1,520
looking for a automatic Differential Pressure Bypass valve
on the system loop of a multi zone hydronic system
with 1-1/4" union connections -
any recomendations?
any recomendations?
Honeywell makes exactly that...
I don't have the number, though.
Noel0 -
yes: but the DU-145 comes with 3/4 connections
my system flow is 11.7 gpm if just the smallest 1gpm
zone is on, i need to bypass 10.7gpm which is a lot
for 3/4"0 -
They make two sizes, and I think the bigger one is 1 1/4".
Noel0 -
While Honeywell, the 1¼" differential pressure bypass valve I bought a few years ago was under the "Braukman" name.
If buying from a supplier where such is uncommon get ready for strange looks and be ready to look it up yourself. Counter man kept asking, "What's it called again? What's it do? I can't find it." After about 15 minutes of this I asked to look in the book, went to the index, found "Differential Pressure Bypass Valves" listed, turned to the page and gave him the model number. Gave him the book still turned to the page headed "Differential Pressure Bypass Valves" and he AGAIN asked, "What's it called?"
Here's where I used two of them.
A work in progress:
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
the one you are showing is the new d146 which comes
in 3/4 and 1-1/4 but is NPTxNPT 90 only
the du-145 is comes in straight union, but 3/4 only
i called the Honeywell Water Controls braukman div
and the engineer said the the D146 is all the sell
for this now.
thanks kal
ps the data sheet for this is at
http://www.honeywell.ca/braukmann/products/pdf/d146.pdf
attached is my system diagram in pdf0 -
AVDO Constant Flow Control Valve
my supplier refuses to get me the braukman
- he says, it's to expensive (read - too little profit)
i found avdo25 from danfoss that has 1" union connectors, close enough -
does anyone have any experiance with it???
http://www.danfoss.ca/catalog/heating/pdf/VD.55.K6.22.pdf0 -
AVDO
Karl go with it.
from ourstand point an extremely trouble free product to sell
Bill0 -
I like Heatlink
I don't know about Danfoss, but.
I always use the Heatlink models, but then I always use Heatlink radiant materials, so that is just what I'm comfortable with. Never had a problem. They may be priced more like Brackman which is high quality as well. They come in 3/4", 1" and 1 1/4" but the flow is what is important and you would have to check their charts on the website for that.
Paul
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
New numbers
Sparco-Braukmann are now part of Honeywell water controls. We make 2 models, a D146M1032, 3/4 inch and a D146M1040 1 1/4inch. Sounds like your distributor is having a bad day...If you can tell me who he is, maybe I can help. Email me direct, not on the Wall, please.0 -
after a second look
i noticed your supports stands made from threaded rod into strut connectors
real cute0 -
Braukmann
D146M140 (1-1/4")
D146M132 (3/4")
EIN
PAB's
are fairly simple devices I imagine any brand would be trouble free. Danfoss, Honeywell and Oventrop are brands I use.
One tip, if I may. Always put a ball valve next to one side. This allows you to purge your system without a bypass. Without isolation purging can be tricky.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 167 Indoor-Air Quality
