Differential Pressure Bypass valve
Kal Row
Kal Row Member Posts: 1,520
looking for a automatic Differential Pressure Bypass valve
on the system loop of a multi zone hydronic system
with 1-1/4" union connections -
any recomendations?
  • Honeywell makes exactly that...
    I don't have the number, though.
    Noel
  • Kal Row
    yes: but the DU-145 comes with 3/4 connections
    my system flow is 11.7 gpm if just the smallest 1gpm
    zone is on, i need to bypass 10.7gpm which is a lot
    for 3/4"
  • They make two sizes, and I think the bigger one is 1 1/4".
    Noel
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    While Honeywell, the 1¼" differential pressure bypass valve I bought a few years ago was under the "Braukman" name.
    If buying from a supplier where such is uncommon get ready for strange looks and be ready to look it up yourself. Counter man kept asking, "What's it called again? What's it do? I can't find it." After about 15 minutes of this I asked to look in the book, went to the index, found "Differential Pressure Bypass Valves" listed, turned to the page and gave him the model number. Gave him the book still turned to the page headed "Differential Pressure Bypass Valves" and he AGAIN asked, "What's it called?"
  • JohnNY
    JohnNY Member Posts: 3,325
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Kal Row
    the one you are showing is the new d146 which comes
    in 3/4 and 1-1/4 but is NPTxNPT 90 only
    the du-145 is comes in straight union, but 3/4 only
    i called the Honeywell Water Controls braukman div
    and the engineer said the the D146 is all the sell
    for this now.
    thanks kal
    ps the data sheet for this is at
    http://www.honeywell.ca/braukmann/products/pdf/d146.pdf
    attached is my system diagram in pdf
  • Kal Row
    AVDO Constant Flow Control Valve
    my supplier refuses to get me the braukman
    - he says, it's to expensive (read - too little profit)
    i found avdo25 from danfoss that has 1" union connectors, close enough -
    does anyone have any experiance with it???
    http://www.danfoss.ca/catalog/heating/pdf/VD.55.K6.22.pdf
  • Mr. Bill
    Mr. Bill Member Posts: 71
    AVDO
    Karl go with it.
    from ourstand point an extremely trouble free product to sell
    Bill
  • Paul_11
    Paul_11 Member Posts: 210
    I like Heatlink
    I don't know about Danfoss, but.
    I always use the Heatlink models, but then I always use Heatlink radiant materials, so that is just what I'm comfortable with. Never had a problem. They may be priced more like Brackman which is high quality as well. They come in 3/4", 1" and 1 1/4" but the flow is what is important and you would have to check their charts on the website for that.
    Paul
    Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
    NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
    A REAL GOOD PLUMBER, INC
    NYC LMP: 1307
    O:212-505-1837
    M:917-939-0593
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    New numbers
    Sparco-Braukmann are now part of Honeywell water controls. We make 2 models, a D146M1032, 3/4 inch and a D146M1040 1 1/4inch. Sounds like your distributor is having a bad day...If you can tell me who he is, maybe I can help. Email me direct, not on the Wall, please.
  • Kal Row
    after a second look
    i noticed your supports stands made from threaded rod into strut connectors
    real cute
  • Einsiedler
    Einsiedler Member Posts: 61
    Braukmann
    D146M140 (1-1/4")
    D146M132 (3/4")
    EIN
  • hr
    hr Member Posts: 6,106
    PAB's
    are fairly simple devices I imagine any brand would be trouble free. Danfoss, Honeywell and Oventrop are brands I use.
    One tip, if I may. Always put a ball valve next to one side. This allows you to purge your system without a bypass. Without isolation purging can be tricky.
    hot rod
