Flat CompressionTanks.......hb
heatboy
heatboy Member Posts: 1,468
a flat compression tank with an acceptance volume of 3 gallons? It is equivalent to a Watts/Amtrol #30. It would be a big help on my panels. Anyone?
hb
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Rectangular? tanks
    http://www.greertank.com/products.htm
    http://www.wel-built.com/SingleWallRECTANGULARtanks.htm
    Can't really find any bladder-type rectangular tanks if that's what you're looking for.
    Looks like you could have them custom made (probably mucho $$$) sans the bladder/diaphragm.
    Sorry I can't find anything closer...
  • Cosmo_2
    Cosmo_2 Member Posts: 43
    I got your tank...RIGHT HERE!!!
    You didn't have to look too far for an answer my friend... Call John Stack Sales for a distributer list
    Cosmo
  • Cosmo_2
    I got your flat tank... RIGHT HERE
    You did'nt have to go too far to find this, I was only a Beep away!! I have used these in some tight spots and they work well. www.caleffi.com go to the the product catalog and look for expansion tanks, can't miss 'em. John Stack Sales carries the Caleffi line, you call call them to find a distributer.
    Cosmo
  • heatboy
    You are way ahead..........
    of the curve, lad! Thanks for the help. I'll call Wheels in the AM. Breakfast Saturday, 7:30?
    hb
    hot_rod Member Posts: 26,645
    I see Kitec
    has a flat rectangle shaped tank on their prefab panels. You might rundown their source.
    Watts used to have them in their hydronic catalog also, an Italian import, I believe.
    hot rod
  • jim sokolovic
    jim sokolovic Member Posts: 439
    Watts rectangular expansion tank
    Watts does still carry 2 models of the rectangular expansion tanks, which are indeed made in Italy. We supply them with our Prodigy boilers. The larger one, the EFT-2, has an acceptance volume of 2.2 gallons. The Amtrol # 30 tank has an acceptance volume of 2.5 gallons (unless the old info I have has changed on either of these).
