Flat CompressionTanks.......hb
heatboy
Member Posts: 1,468
a flat compression tank with an acceptance volume of 3 gallons? It is equivalent to a Watts/Amtrol #30. It would be a big help on my panels. Anyone?
hb
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hb
Rectangular? tanks
http://www.greertank.com/products.htm
http://www.wel-built.com/SingleWallRECTANGULARtanks.htm
Can't really find any bladder-type rectangular tanks if that's what you're looking for.
Looks like you could have them custom made (probably mucho $$$) sans the bladder/diaphragm.
Sorry I can't find anything closer...0 -
I got your tank...RIGHT HERE!!!
You didn't have to look too far for an answer my friend... Call John Stack Sales for a distributer list
CosmoThere was an error rendering this rich post.
I got your flat tank... RIGHT HERE
You did'nt have to go too far to find this, I was only a Beep away!! I have used these in some tight spots and they work well. www.caleffi.com go to the the product catalog and look for expansion tanks, can't miss 'em. John Stack Sales carries the Caleffi line, you call call them to find a distributer.
You are way ahead..........
of the curve, lad! Thanks for the help. I'll call Wheels in the AM. Breakfast Saturday, 7:30?
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
I see Kitec
has a flat rectangle shaped tank on their prefab panels. You might rundown their source.
Watts used to have them in their hydronic catalog also, an Italian import, I believe.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Watts rectangular expansion tank
Watts does still carry 2 models of the rectangular expansion tanks, which are indeed made in Italy. We supply them with our Prodigy boilers. The larger one, the EFT-2, has an acceptance volume of 2.2 gallons. The Amtrol # 30 tank has an acceptance volume of 2.5 gallons (unless the old info I have has changed on either of these).0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
