Need a diagram
Unknown
Member
I haven't found the one I'm looking for yet.
Noel
Noel
I'm looking for a diagram
That shows the water heater set-up with a heat exchanger and a monoflow tee that moves the water through the heat exchanger and water heater during the non-heating season. I know the gist of it, but I'm looking for a diagram from someone that has done it and had it work properly.
The application is a small floor warming project in a forced air house.
Noel0 -
I thought Bock might have it,
but they use a mixing valve.
Maybe you can interpolate the fitting into this:
http://www.bockwaterheaters.com/technical/pdf/installation_section1.pdf0 -
Thanks, George
I'll try that.
Hot Rod, or Bob, or somebody reccomended this a while ago, and I never wrote it down. I'll learn, someday...
Noel0 -
I don't have it connected to
a system, but if you look in the July issue of Fuel Oil News I have one (Jet-T) hooked up to a water heater.
http://www.petroretail.net/fon/2003/0307/0307brn.asp0 -
ME is your guy
He has an idea for such a setup. Can't seem to find a copy of it on my heaped desk!
hot rodBob "hot rod" Rohr
Here tis...
It's a biggy.
ME0 -
induced flow or pumped
I'm a little confused as to the reason for the venturi tee since the diagram shows a circ pump between the h2o htr and the HX, are both necessary or am I missing somthing??0 -
venturi tee
keeps flow going thru the heat exchanger during the off heating months. This way you don't have stagnation in the HX and a possible breeding ground for bugs. Everytime hot water is used it flows water thru the HX keeping it clean (?).
Scott
Thank you very much
You guys are the greatest.
Noel0 -
Right-O- (NM)
ME0
- 50 Industry Classes
