twining two gas water heaters
jim f
jim f Member Posts: 182
i'm looking to twin two gas fired water heaters in a residential home. looking for piping diagrams and info on how i can install so i get max efficency and distribution........
thanks
jim franze
www.tri-city heating and cooling.com
  • stan_2
    stan_2 Member Posts: 12
    twining water heaters
    Jim, try going to bradford-white.com I was just there today, you might find something there.
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Jim,
    there are two common ways: one is two make sure the two tanks are piped equal distance from the tees for both the cold and the hot water. The second is to do a reverse return-feed one tank with cold water then the second, then take the hot water from the second and then tie in the first. This is a self balancing system that requires a little more piping but assures equal distribution.
    Sorry, I do not have the ability to draw sketches but someone probably will.
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Getcher sketches heah...
    .Sorry about the size, it's a big system. The closed loop draws off of the outter closed loop system. It is NOT an open and direct system. The heat source is assumed to be a Phase 3 boiler/DHW combination.
    ME
