twining two gas water heaters
jim f
Member Posts: 182
i'm looking to twin two gas fired water heaters in a residential home. looking for piping diagrams and info on how i can install so i get max efficency and distribution........
thanks
jim franze
www.tri-city heating and cooling.com
thanks
jim franze
twining water heaters
Jim, try going to bradford-white.com I was just there today, you might find something there.0 -
Jim,
there are two common ways: one is two make sure the two tanks are piped equal distance from the tees for both the cold and the hot water. The second is to do a reverse return-feed one tank with cold water then the second, then take the hot water from the second and then tie in the first. This is a self balancing system that requires a little more piping but assures equal distribution.
Sorry, I do not have the ability to draw sketches but someone probably will.0 -
Getcher sketches heah...
.Sorry about the size, it's a big system. The closed loop draws off of the outter closed loop system. It is NOT an open and direct system. The heat source is assumed to be a Phase 3 boiler/DHW combination.
ME0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 970 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
