big kick space heater?
Steve Levine
Steve Levine Member Posts: 106
Should be able to do the job. It is also relatively easy to get the required water flow because the coil is manifolded. Most others are not.
But be careful, to get the max output the fan must be run at high speed. Most begin to get a lottle noisy at high speed.
See; http://www.slantfin.com/spec-kicker.html
Steve Levine
