big kick space heater?
Steve Levine
Member Posts: 106
Should be able to do the job. It is also relatively easy to get the required water flow because the coil is manifolded. Most others are not.
But be careful, to get the max output the fan must be run at high speed. Most begin to get a lottle noisy at high speed.
See; http://www.slantfin.com/spec-kicker.html
Steve Levine
Steve Levine
Hi Guys,
Gotta job where I need 9900 BTU from a kicker... am I gonna need two, or is there one out there?
Gary0 -
beacon morris k120
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
