Taco Relay
Richard D.
Member Posts: 32
I am installing a 3 zoneCast Iron Boiler..2 heat 1 Super Stor...The S/S is wired to the Cold Start relay...From the Taco 502 relay what is the bestway to wire it so the burner pulls in on demand..Taco shows zr/zc hook up for tankless and for cold start they shot the end switch going to T T..I want to go to the limit of the controll.( Blue wire} if I am right..Do I use ZR to the limit???Do I leave in all jumpers???Thanks...Richard
hey rich
I think you need the 503 for this job. paul.0 -
You can use the 502
We use them often on 3 zone system with a priority . At the Taco website they have instructions on how to wire it up . One problem though - the online diagrams are screwy - some terminals do not line up right in the schematics . If theres a rep from Taco who checks in here , they might want to take a look . If you follow the instructions underneath the diagrams , its pretty easy to follow , and they tell you where to put jumpers in and how to wire it for a priority indirect . Heres the link - http://www.taco-hvac.com/uploads/Product_Install/12.pdf0 -
Like Paul said...
Get a 503 W/ priority. Easiest thing to do what you want .
JMHO. Chris0 -
Taco Relay
Thanks all for your help..I may have the number wrong on the relay..It is a 2 zone relay,but I agree a 3 zone would be easier,but I do like to wire things out of the norm of easy... sometimes... I check out the website and if any1 wants I can draw a new wiring template for cold start w/cir ..on aqua stat and xtra relay...Their wiring pics are like the Pensottie Blue,very mind twisting till you figure out how they write them ...Thankyou all for your help..Richard
If the 2 zone relay is on the boiler already
You can use a Taco single zone relay to do what you want also . We use them alot where we install an indirect to an existing boiler . Its a little more involved in wiring up though , but it will give priority to the indirect , as well as keep the system cold start . Is the boiler gas or oil ?0 -
Taco
Hey Ron it is oil and the controlls are there..I am trying to find out if I use the Z/R terminal off the 502 to power ths cold start controll!Tacoweb site is not helpfull with this install..I am already wired w/xtra wires in place...I am thinking Z/R to the cold side of aqua stat..Do yoy know if Z/R powers on demand for heat???Thankyou everyone for your help...Could not find e mail support @ TAco...Richard0 -
Theres an isolated end switch on the 502
Its X1 and X2 . If you run a wire from them to the boiler's T-T , it will kick on the burner in a call for heat . But if you still have the indirect circulator connected directly to the cold start aquastat , this wont work because it will turn on the indirect all the time the heating zones kick on . And that is also part of the reason you cant use ZR to power the burner . Well , you can use ZR , but it will need to go through a separate aquastat on the boiler to control the burner separately . What model number aquastat is on the boiler ?
Hey Ron
If I have it right it is a Honeywell 8124 cold start...or 8248..I know I can use one side of the controlllimit buut not sure which 1 on the taco to sendpower to the aqua stat...The wires are blue on top and I think red ...that will power the burner with out powering the S/S zone
//// Thankys Richard
R.D.
I know what you are trying to do but I have not had a Taco relay in a while. The wire you want on the 8148 is blue. You can tell because your torx screw driver won't fit the red one, it has a pin in the center so you can't miswire.
ZR would be the connection that would send power or a call for heat. If you had X1 X2 terminals you could jumper X1 to L1 and X2 would go to your blue wire on the 8148. In a case where you have no ZR or X terminal you could piggy back with the pump terminal if it does not exceed the amp draw of the contactor.
You can rewire around almost anything when you understand how. I just hate it when people make it a mystery to the next guy who comes along. Make sure the power has a common disconnect. And to any eletricians who may be listening, they sell wire in more colors than black and white. It helps when troubleshooting later0 -
Hey Bill
L.O.L. I hear you about color code..I have all the wires colored coded . and will return on wed. to hook up...Thankyou for your input,at least I know I am on the right track..Wish TACO would offer more options..But at least I have you guys here at the wall for my TECH. Support...Thanks and hope to return the favor to you all...Richard0 -
Oh Bill,
Do you ever "not speak the truth"? I wish I had a nickle for every time I saw black and white only. I have found a few that have numbered stickers for the terminus', but they are few and far between . Guess you had to be there. (that's the way I hear it from electricians so far) Chris0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
