Pre-measured pieces/fittings for headers.
JohnNY
Member Posts: 3,317
It seems to me that every boiler manufacturer should be able to give you a list of fittings and cut pieces/nipples needed to pipe the header on every steam boiler they make.
The only variation being the number of supply tees on the header.
I heard something about Weil-McLain doing something like that but never got confirmation.
Any information out there?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Burnham has the list
to pipe their steam boilers in threaded pipe and fittings . They even have the list for a drop header . We got the diagrams with the info packets on the boiler when we first started using them . I'm sure Glenn Stanton can point you in the right direction if you want the list .0 -
Any boiler
MFG's reading this? I'd like the information as well.0 -
Yes
I am. I think that is a good idea. I'll do just that. I'll let the wall know how to find it, as well as the contractors installing steam boilers.
Do you use Slant/Fin boilers?
Noel0
- 109 Chimneys & Flues
- 973 Plumbing
- 386 Solar
- 17 Recall Announcements
