Repairing Header
Mad Dog
Member Posts: 2,595
hurt...get help from another strong dude too...Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=299&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Repairing/Replacing Header
I am a HO with the only steam/vapor system in my area. I am repairing/replacing the header to properly pipe. I have been able to remove some of the pipes but some seem to be too stubborn to remove. Any suggestions? Should I heat the joints up. I'd like to reuse some of the elbows and other piping if possible. Any suggestions on how to loosen the old pipes?0 -
Suggestions
Free advice is just that,........ free advice. It is not always what you might want to hear.
I would not waste a great deal of time trying to save the old fittings. If they are not bigger that 2" IPS , the new fittings are not expensive. 2-1/2" and up are a little more , but still not that much.
I would concentrate on saving the threaded end of the pipe that is in place.
After saying that, Brute Strength, a very large pipe wrench, [or two] a length of pipe to slide over your pipe wrench handle and sheer determination work best. The problem here is you often damage the fitting by causing it to become out of round, egg shaped, or they crack.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
