Fire sprinkler system question--Mad Dog sent me
Jim_47
Jim_47 Member Posts: 244
Just a thought, All commercial fire systems, and I would want this protection if it were my house, have a backflow prevention device between the fire system and the water system. You do not want that stagnant water backing up into your domestic water if you loose pressure. It would be a minimum if the system is installed. Code also dictates it, and NYS health dept requires annual testing. (as do most states). Good luck on your new adobe.
Jim
  • Joe P
    Joe P Member Posts: 2
    I am looking for a licensed fire sprinkler contractor in Northern New Jersey to install a system in my new home (currently under construction). The system design has already been made (I used the same designer Mad Dog used), but now I need to find someone to make it work. Any ideas?
  • Joe P
  • Mad Dog
    Mad Dog Member Posts: 2,595
    Calling all Fire Sprinkler Contractors in Northern Jersey
    Joe needs an install on a residential CPVC system. Mad Dog
  • Douglas Hicks
    Douglas Hicks Member Posts: 69
    residential Sprinkler System
    Go to NFSA.org, then to contractors and then to New Jersey to find contractors in your area. Contact them, ask for lisences, bonds and workers comp coverage. Ask for references.
    Douglas Hicks
    General Fire Eqipment Co of Eastern Oregon, Inc
