Fire sprinkler system question--Mad Dog sent me
Jim_47
Member Posts: 244
Just a thought, All commercial fire systems, and I would want this protection if it were my house, have a backflow prevention device between the fire system and the water system. You do not want that stagnant water backing up into your domestic water if you loose pressure. It would be a minimum if the system is installed. Code also dictates it, and NYS health dept requires annual testing. (as do most states). Good luck on your new adobe.
Jim
Jim
I am looking for a licensed fire sprinkler contractor in Northern New Jersey to install a system in my new home (currently under construction). The system design has already been made (I used the same designer Mad Dog used), but now I need to find someone to make it work. Any ideas?0 -
Calling all Fire Sprinkler Contractors in Northern Jersey
Joe needs an install on a residential CPVC system. Mad Dog
residential Sprinkler System
Go to NFSA.org, then to contractors and then to New Jersey to find contractors in your area. Contact them, ask for lisences, bonds and workers comp coverage. Ask for references.
Douglas Hicks
General Fire Eqipment Co of Eastern Oregon, Inc0
