pex
are any brands of straight pex easier to work with (pliable)than others.?
also any info on actual how to ideas on roughing in and using pex for home runs?(through and around framing?)
    hot_rod Member Posts: 26,645
    Is this for
    radiant or hydronic use? If so make sure you use barrier pex.
    I've found Wirsbo to be quite supple. Any pex kept in the sun for an hour or so gets much more managable.
    On the other end of the spectrum PAP (pex al pex) is nice to work with if you like forming nice sweeping bends. I believe Kitec offers straight lengths of potable and heating pex.
    hot rod
  • nathan gugenheim
    nathan gugenheim Member Posts: 26
    hydronic use for home runs
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I have....
    used Vanguard pex 3/8" pex for potable water for years. this is non barrier not for heat.Is is great w/ their manabloc/manifold. kpc
