pex
nathan gugenheim
Member Posts: 26
are any brands of straight pex easier to work with (pliable)than others.?
also any info on actual how to ideas on roughing in and using pex for home runs?(through and around framing?)
Is this for
radiant or hydronic use? If so make sure you use barrier pex.
I've found Wirsbo to be quite supple. Any pex kept in the sun for an hour or so gets much more managable.
On the other end of the spectrum PAP (pex al pex) is nice to work with if you like forming nice sweeping bends. I believe Kitec offers straight lengths of potable and heating pex.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
hydronic use for home runs0 -
I have....
used Vanguard pex 3/8" pex for potable water for years. this is non barrier not for heat.Is is great w/ their manabloc/manifold. kpc0
