You need to read this (PAH)
hot_rod
hot_rod Member Posts: 26,638
http://home.hamptonroads.com/stories/story.cfm?story=56640&ran=83915
This paragraph packs a visceral punch:
" A hotel air-conditioning system was implicated in the defining outbreak of Legionnaires' disease at an American Legion convention in Philadelphia in 1976, although newer data indicate that hotel water may have caused the problem."
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • flange
    flange Member Posts: 153
    didnt read your link, however its general knowledge that there was a cross connection at the cooling tower loop with no backflow or even a check valve. that coupled with the poorly treated tower did them in.
    sounds like
    an open system! Where have I heard that before?
    The bodies are beginning to be counted.
  • Earthfire
    Earthfire Member Posts: 543
    legionar's hot tub
    Don't think that the hot tub dealer used enough chemicals.Question is did the water supply at the arena introduce the bacteria to the tub or did it come from an improperly treated display tub at the dealers showroom?
  • Dave Yates (PAH)
    Dave Yates (PAH) Member Posts: 2,162
  • Earthfire
    water fountains
    Now I know why I never use water fountains in public buildings. Nothing like stagnant water in a closed up building to grow goo in. Except maybe that electric waterheater in the basement that's valved of all heating season while the domestic coil on the boiler is making hot water, and gets turned on for the summer to "save" on oil.
