You need to read this (PAH)
hot_rod
Member Posts: 26,607
http://home.hamptonroads.com/stories/story.cfm?story=56640&ran=83915
This paragraph packs a visceral punch:
" A hotel air-conditioning system was implicated in the defining outbreak of Legionnaires' disease at an American Legion convention in Philadelphia in 1976, although newer data indicate that hotel water may have caused the problem."
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
didnt read your link, however its general knowledge that there was a cross connection at the cooling tower loop with no backflow or even a check valve. that coupled with the poorly treated tower did them in.0 -
sounds like
an open system! Where have I heard that before?
The bodies are beginning to be counted.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
legionar's hot tub
Don't think that the hot tub dealer used enough chemicals.Question is did the water supply at the arena introduce the bacteria to the tub or did it come from an improperly treated display tub at the dealers showroom?0 -
traced
It was traced to the potable water supply lines.
water fountains
Now I know why I never use water fountains in public buildings. Nothing like stagnant water in a closed up building to grow goo in. Except maybe that electric waterheater in the basement that's valved of all heating season while the domestic coil on the boiler is making hot water, and gets turned on for the summer to "save" on oil.0
- 167 Indoor-Air Quality
