Cast Iron Baseboard
Jan
Member Posts: 2
I have a job to install cast iron baseboard in a doctor's office. One of the carpenters on the job asked why I didn't use baseboard that was designed to cover (be installed over) the 7 inch base moulding that they were installing. They described baseboard that sounded like it had a lip on the top that held the baseboard off the wall while covering up the moulding. I've never seen or heard of baseboard like this, but it really would make the job easier. anyone have any information?
cast iron baseboard
I have a job to install cast iron baseboard in a doctor's office. One of the carpenters on the job asked why I didn't use baseboard that was designed to cover (be installed over) the 7 inch base moulding that they were installing. They described baseboard that sounded like it had a lip on the top that held the baseboard off the wall while covering up the moulding, kind of like an inverted L. I've never seen or heard of baseboard like this, but it really would make the job easier. Anyone have any information?0 -
I've not seen any
Nor have I heard of any made.
Slant/Fin makes recessed and surface mounted baseboard, but the trim is usually not installed behind it.
Noel0 -
Ask
The carpenters to install that trim that covers your baseboard.
Scott
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 167 Indoor-Air Quality
