Noisy Water Meter (off topic)
hot_rod
Member Posts: 26,625
the noise is only heard when flowing large GPM, like a hose bib. Is it noisey under low flow? They may have put in a smaller capacity meter also, perhaps a 5/8", maybe spinning fairly fast.
Meters are built with some "slop" to allow them to pass some particles, most are merely a wobble plate mechanism. Maybe a plastic meter would be less prone to noise transmission??
hot rod
hot rod
Noisy Water Meter (OT)
Been hearing a perfect tempo tap tap tap noise in my bathroom last few days. Figured out it only happens when water is running somewhere else in house (like washer machine or sprinklers).
After crawling around in crawlspace traced the noise to the water main (which comes up under the bathroom where I heard the noise). Went outside to the water meter "vault" and saw a new cover with a plastic doohickey on it. Opened it up and found a new water meter with a wire lead to the lid. Must be a remote meter reader.
When the water runs, this new meter clacks LOUD like a Model T!! Besides it being slightly annoying, is it supposed to be so noisy? I never heard the old one, and I have looked into the vault before.0 -
Ahhh the suttle click click click of the water meter to help lull you off to sleep. Many of the older meters I come across have this same glitch. I would either call the city and let them know you are not happy with the noise, or isolate the meter from the main with a vibration eliminator.
Just my opinion,
Andy N.0 -
I wonder
if a large water hammer arrestor placed near the meter would do any good ? Have heard that noise a lot over the years!
noisy times
Even if the sink faucet is running just enough to wash your hands, you can hear the tap. Altho it is slower than when the sprinkler is on or the washer is filling. The pattern changes too when slower flow. Tap...tap...tap.. tappity tap...tap...tap maybe it's a drum cadence?
maybe
maybe its morse code. is your plumbing system trying to tell you something? At least you will be able to tell if you forgot to turn off the sprinkler, or if you have a leaky ball cock.
just kidding around,
Andy0 -
Could be
just the type of meter or maybe has something lodged in the housing. Ask the city to replace it,would be a simple first step. Maybe it is in the sending unit and not the meter. Any neighbors with the same noise?
hot rodBob "hot rod" Rohr
Morse Code
I looked for anyone trapped in the crawl space or frogs in the meter vault!
I'll ask one of my neighbors if their new meter makes noise too, next time I see them.
It will be "interesting" to see how the water co. handles the meter reading change on my nex bill. I know the reading from my last bill, but not on the day they switched to a new "odometer" starting at "00000".
- 167 Indoor-Air Quality
