Heat Timer Problems
c gray
c gray Member Posts: 1
I am a condominium Trustee in the Boston area not looking forward to the
winter heating season. The building is approximately 60+ years old, our
boiler is a Weil-McLain and is approximately 10 years old. We have a
Heat-Timer EPU unit regulating temperature by monitoring outside
temperature. The unit was manufactured in 1997.
Our service provider has said that the timer function on this unit is
faulty such that the whole unit needs to be replaced. Provider wants to
replace the unit with a digital one at a cost of approximately $4K.
So, here are a couple of questions:
1. Have anyone had experience with products from Heat-Timer?
2. If so, what would be your estimate of the life span of this unit?
Any other info you would care to add would be helpful.
TIA,
-C
