Orifice Valves
Anyone out there still making orifice valves. I am installing a few radiators that were removed years ago. My current system uses Bi-Loop orifice valve (two-pipe vapor system),and I would like to use that type of valve if its out there. If not, what valves and traps are recommended. Or, I guess I could simply use orifices in the valves.
Thanks,
Chemeclimber
