Orifice Valves
Chemeclimber
Member Posts: 9
Anyone out there still making orifice valves. I am installing a few radiators that were removed years ago. My current system uses Bi-Loop orifice valve (two-pipe vapor system),and I would like to use that type of valve if its out there. If not, what valves and traps are recommended. Or, I guess I could simply use orifices in the valves.
Thanks,
Chemeclimber
Thanks,
Chemeclimber
Better idea, CC
Get TRVs for your bedroom radiators and move the existing Bi-Loop valves to the ones you're re-installing. Reset the shutters on the Bi-Loops if you need to.
I just got these Honeywell/Braukmann TRVs and they are approved for use with steam. You'd need to use disc orifices with them on your system though.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
oriface valves
MEPCO, formaly Dunham Bush still has adjustable oriface valves and the last I knew still had orface plates.
Try
https://www.statesupply.com/
p0 -
I am really impressed with Tunstall
Noel put me on to them. High quality, cheap, and great service. I also like Steamhead's idea. Tunstall makes nice TRVS too. Mad Dog
orifice valves
thanks for the plug boys...here we are willing and able.....tp tunstall0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
