Looking for an inexpensive wall hung boiler.
I am doing an in-floor radiant install in a 30X40 garage. The customer would like to have a wall hung LP gas boiler to save on floor space. The only wall hungs that I am familiar with have all kinds of control goodies and indirect DHW.
Are there any "duh" wall hung boilers for a simple, one temperature installation that only calls for 40,000 BTU's?
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    well inexpensive is...
    a relative term....How about the Weil-Mcl AHE-60... Another option I did once was using a 30,000 btu water heater as the boiler.(no domestic was taken off the system)just slab heat... worked, albeit its not the most efficient way...maybe 75% afue....kpc
  • MURPH'_2
    MURPH'_2 Member Posts: 20
    how's about .......
    building a shelf ??
  • JohnNY1
    JohnNY1 Member Posts: 62
    Check out the Rinnai. I just put one in on Thursday. Nice and easy. Works well.
    www.rinnaina.com
  • Josh M.
    Josh M. Member Posts: 359
    I have found the Tagagi to be the best for this kind of install. The advantage to Rinnai is you can use the standard stainless vent pipe as opposed to Rinnai's expensive type.
  • MikeTH
    MikeTH Member Posts: 14
    Baxi 1.31Fi
  • MikeTH
    Baxi 1.31Fi
    Hey Steve, take a look at the Baxi 1.31Fi. Wall hung heat only boiler which is supplied as a package including the venting, pump, fitting valve package and the heat/ex is "H" stamped. It has a modulating burner and can be set for heat outputs from 40000-105000 BTU's, all this plus a switch on the controls to operate the boiler at 45*C for low temp applications. They have been availlable in North America for 5years but have been used extensivly in Europe for 25+ years, check out the web site.
    www.wallhungboilers.com
  • Einsiedler
    Einsiedler Member Posts: 61
    best buy - price wise
    Best buy on wall mounts thus far, I've found to be the NTI Trinity.
    Visit http://www.nythermal.com/
    for more information and/or rep in your area.
    Regards,
    Terry @ Frontier
  • Dan Peel
    Dan Peel Member Posts: 431
    Small load
    The load's a little light for the Trinity. At 50m -150m modulation it'd never get off low fire even on a design day. Your garage won't need very many candles to heat it. Dan
  • Mike Norgan_3
    Mike Norgan_3 Member Posts: 105
    Vitodens
    The Viessmann Vitodens, Hang it, pipe it, and plug it in how much easier can it get. The smaller unit will modulate down to 25,000 btu's.
    Mike
  • Steve Bergerson
    Steve Bergerson Member Posts: 38
    Thanks Everyone!
    The Wall is great!!
    I've got more ideas than hours to ponder them now! I'm going to check with my suppliers who carry some of the brands recommended here and pick a solution.
