Looking for an inexpensive wall hung boiler.
Steve Bergerson
Member Posts: 38
I am doing an in-floor radiant install in a 30X40 garage. The customer would like to have a wall hung LP gas boiler to save on floor space. The only wall hungs that I am familiar with have all kinds of control goodies and indirect DHW.
Are there any "duh" wall hung boilers for a simple, one temperature installation that only calls for 40,000 BTU's?
well inexpensive is...
a relative term....How about the Weil-Mcl AHE-60... Another option I did once was using a 30,000 btu water heater as the boiler.(no domestic was taken off the system)just slab heat... worked, albeit its not the most efficient way...maybe 75% afue....kpc0 -
how's about .......
building a shelf ??0 -
Check out the Rinnai. I just put one in on Thursday. Nice and easy. Works well.
www.rinnaina.com
I have found the Tagagi to be the best for this kind of install. The advantage to Rinnai is you can use the standard stainless vent pipe as opposed to Rinnai's expensive type.0 -
Baxi 1.31Fi
Baxi 1.31Fi
Hey Steve, take a look at the Baxi 1.31Fi. Wall hung heat only boiler which is supplied as a package including the venting, pump, fitting valve package and the heat/ex is "H" stamped. It has a modulating burner and can be set for heat outputs from 40000-105000 BTU's, all this plus a switch on the controls to operate the boiler at 45*C for low temp applications. They have been availlable in North America for 5years but have been used extensivly in Europe for 25+ years, check out the web site.
www.wallhungboilers.com
best buy - price wise
Best buy on wall mounts thus far, I've found to be the NTI Trinity.
Visit http://www.nythermal.com/
for more information and/or rep in your area.
Regards,
Terry @ Frontier
Small load
The load's a little light for the Trinity. At 50m -150m modulation it'd never get off low fire even on a design day. Your garage won't need very many candles to heat it. Dan
Vitodens
The Viessmann Vitodens, Hang it, pipe it, and plug it in how much easier can it get. The smaller unit will modulate down to 25,000 btu's.
Mike0 -
Thanks Everyone!
The Wall is great!!
I've got more ideas than hours to ponder them now! I'm going to check with my suppliers who carry some of the brands recommended here and pick a solution.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
