Tankless water heater vs indirect water water heater/tank
chuck shaw
Member Posts: 584
reccomend a tankless water heater, I just havent had good luck with them. The newer gas models may be better than the ones I have seen in the past. If you already have a Buderus boiler you are 90% of the way to a great system. Get a 40 gallon Buderus indirect, and you will never run out of hot water.
JMO
Chuck
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
JMO
Chuck
Here I go again.. the answer to my previous question about venting was sooo darn helpful in helping me understand all this, that I just had to throw another one out.
Ok.. take this equipment
Buderus G115-28 boiler w/r2107 controller
Riello BF5 balanced flu burner
Some brand of baseboard..
The house is smallish at around 1200sq feet with two occupants. Maybe 1 child down the road, definitely not more than 2. House has 2 bedrooms effectively. Third room is study/computer room.
The choice.. a tankless hotwater system without storage tank, or an indirect water heater, such as a 40 gallon Superstor Contender. Any suggestions on which would be better to go with? I would think the tankless system would provide enough hot water for 2-3 occupants, but I have some concerns. Some people say the tankless systems can get a bit finicky during the winter months when the incoming water temperature is much lower. Looking for something practical and efficient. I'm all ears
Thanks again.0 -
I would concurr...
as you already know Buderus does not have a tankless w/ their boilers. get a good brand of indirect...superstor.phase 3,buderus and start saving $ right away...kpc0 -
tankless
Sounds good thanks. I wasn't sure the Buderus had a tankless or not.. couldn't find any reference to it, so now I know why.
G
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
