Started a new radiant install today-Mike Norgan
This is a new job we started today, The project is a slab on grade for the most part, but there is also a small basement and a long hallway for the plumbing and heating and what what ever else it needs to be used for. The pictures just so the tubing install, I will try to keep updated photos, this is a pretty cool project.
Mike Norgan
  • George_10
    George_10 Member Posts: 580
    New system cleaning and treatment
    Like Hotrod suggested in his RPA article, I wonder if you and other installers of new systems are cleaning and treating before putting into service.
    If you are, I would love to see a picture posted of what comes out of a new system when it is cleaned.
    Good luck on this project.
  • Mike Norgan_3
    Mike Norgan_3 Member Posts: 105
    Pictures
    I will try to post pics when we get a chance to install the boiler.
  • hr
    hr Member Posts: 6,106
    Nice tube job
    What thpe of pex are you using? PAP? Is that a span-deck product for a partial suspended slab? If so, do you insulate the bottom? Show us more as you move along.
    hot rod
  • Mike Norgan_3
    Tubing type
    Hot Rod,
    I use StadlerViega tubing, If that is what you call it that is span decking. The basement is heated and the walls are about ten feet in from the outside footing walls, so for you question, no there is not any insulation below the decking. I'm thinking there shouldn't be a problem. The whole house is going to be all tile, got to love that, the heating curve will be at the lowest setting with constant circulation and outdoor reset, Sweeeeet.
    Mike Norgan
  • Mike Norgan_3
    Project of the week.
    Check out Stadlerviega web sight, I was lucky enough to have my project featured on there web sight for job of the week. www.stadlerviega.com
    Mike Norgan
