Started a new radiant install today-Mike Norgan
Mike Norgan_3
Member Posts: 105
This is a new job we started today, The project is a slab on grade for the most part, but there is also a small basement and a long hallway for the plumbing and heating and what what ever else it needs to be used for. The pictures just so the tubing install, I will try to keep updated photos, this is a pretty cool project.
Mike Norgan
Mike Norgan
New system cleaning and treatment
Like Hotrod suggested in his RPA article, I wonder if you and other installers of new systems are cleaning and treating before putting into service.
If you are, I would love to see a picture posted of what comes out of a new system when it is cleaned.
Good luck on this project.0 -
Pictures
I will try to post pics when we get a chance to install the boiler.0 -
Nice tube job
What thpe of pex are you using? PAP? Is that a span-deck product for a partial suspended slab? If so, do you insulate the bottom? Show us more as you move along.
hot rod
Tubing type
Hot Rod,
I use StadlerViega tubing, If that is what you call it that is span decking. The basement is heated and the walls are about ten feet in from the outside footing walls, so for you question, no there is not any insulation below the decking. I'm thinking there shouldn't be a problem. The whole house is going to be all tile, got to love that, the heating curve will be at the lowest setting with constant circulation and outdoor reset, Sweeeeet.
Mike Norgan0 -
Project of the week.
Check out Stadlerviega web sight, I was lucky enough to have my project featured on there web sight for job of the week. www.stadlerviega.com
Mike Norgan0
- 167 Indoor-Air Quality
