Flow through 1/2\" copper
Dave_13
Dave_13 Member Posts: 110
I have 1/2" water lines and a well. The water pressure is always between 30 and 50 PSI. How do I figure out the flow rate??????
  • Doug_7
    Doug_7 Member Posts: 266
    Flow in 1/2 inch copper tube
    Flow is a function of pressure-drop, which depends on piping length and any other restrictions such as valves.
    Check the Copper Tube Handbook
    http://www.copper.org/tubehdbk/tables/table4.html
  • Jackchips
    Jackchips Member Posts: 344
    A simple
    but effective method is to just put a measured bucket under any faucet, open wide and time it.
    A two gallon bucket filled by a tub in two minutes will be 1 gpm. Etc., Etc.
    Thanks for the math refresher, Brian.
  • Brian (Tankless) Wood
    Brian (Tankless) Wood Member Posts: 222
    I think you mean
    a one gallon bucket filled in 30 sec's is 2 gpm :O)
    Maybe we have different buckets in Swampland :)
    Brian.
